1964 Chevy Corvette noises in chassis
1964 CHEVROLET CORVETTE
GOATBOY10
Noises problem
1964 Chevy Corvette V8 Two Wheel Drive Manual
my 1964 corvette makes a poping noise sometimes when i shift or brake hard usually in left rear of the car or front right sometimes.
it sounds like its coming from the chassis but i am not shure ? any clues on what or where this noise is comming from.
Jul 9, 2009 at 3:21 AM
LOUT5369
  • 217 POSTS
Jack up the car by putting the jack under the lower control arms and check for wheel movement,grab the tire and try to shake it,you may have a bad ball joint,In the rear check the spring mounts at the wheels the bushings may be shot for tranverse spring,also check the u-joints on the axles.GoodLuck,Lou
Jul 29, 2009 at 11:34 PM
