my car dies
1993_CHEVY_CORSICA
ok i was driveing my 1993 chevy corsica and it died while i was driving it, it was like someone turn the key off.then one other day i started it and when i got on the gas it wanted to die but when i let off the gas it would run fine what should i do?
Jun 20, 2006 at 5:16 AM
SWEEP2WIN
  • 21 POSTS
Sounds like you need a tune up. If you already took care of that then the fuel pump would be the next thing I would change. When the fuel pump is going out it will continue to work if you let the car rest, but it will cut off on you at any time any place.
Jun 23, 2006 at 10:38 PM
