MATTHEWP
my car is a 1996 corsica 3100 v-6. when you put the car in gear it wont move only rocking the car back and forth will get the car to go into gear then after a while it locks up again..it is not low on fluid we put fluid thinking it was the problem please help!!!
Feb 3, 2007 at 7:48 AM
HRYK2646
  • 40 POSTS
You might check your Floor shift control cable which connects to the starter safety switch. It put the tranny into the gears.You may have a bad Switch its on top uf the tranny above the tranny filter and pan. Or check the colum shifter or floor shifter.Hope that helps.
Ray
Feb 4, 2007 at 10:37 AM
