You might check your Floor shift control cable which connects to the starter safety switch. It put the tranny into the gears. You may have a bad Switch its on top uf the tranny above the tranny filter and pan. Or check the colum shifter or floor shifter. Hope that helps.
Ray
SPONSORED LINKS
Sunday, February 4th, 2007 AT 6:37 PM
