getting door to open
KINGSCHAPEL
I have a 1989 Chevy Corsica--4door with about 140,000 miles on it. IT DOES NOT HAVE ELECTRIC LOCKS. My problem happened due to a series of ice storms that made two of my doors so they would not open from the outside. My driver's door will not open from the out or inside! I have to open the driver's front door by using the rear door to open the passenger front door and then crossing over to the driver's seat so I can drive my car. It is a terrible pain in the rear and I can't figure out how to open the driver's door so I can try and fix it since I cannot open the door at all.
Aug 25, 2007 at 7:08 AM
  • 75,988 POSTS
[quote:91e8b5d4c0="Kingschapel"]I have a 1989 Chevy Corsica--4door with about 140,000 miles on it. My problem happened due to a series of ice storms that made two of my doors so they would not open from the outside. My driver's door will not open from the out or inside! I have to open the driver's front door by using the rear door to open the passenger front door and then crossing over to the driver's seat so I can drive my car. It is a terrible pain in the rear and I can't figure out how to open the driver's door so I can try and fix it since I cannot open the door at all.[/quote:91e8b5d4c0]
Is this a power lock doors-if so check the fuse and relay -relay should be behind the right side kick panel, or behind right side of IP in relay bracket or glove compartment. Relay/fuse good.
Its gonna be hard working from the inside-Remove the door panel and look for loose wire at motor and test for a short circuit wiring -wire okay-replace door motor.
Aug 25, 2007 at 9:10 AM
