Well, first you need to isolate what cylinder the miss is from, you can do this by using insulated pliers and run the car and pull one plug wire at a time until you find the right one, then check compression and leakdown
jim
SPONSORED LINKS
Friday, February 16th, 2007 AT 5:37 PM
