1996 Chevy Corsica starting
152,019 MILES • 4 CYL • FWD • AUTOMATIC
SKINS101
the car will start at times it may not start than about five mins. later it will start it will just trun over but not start. i have put a new fule pump on it about a week ago also a egr valve. still the same thing . new plugs also
Feb 16, 2010 at 6:24 AM
JDL
  • 16,098 POSTS
Welcome, have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage. Also, they used to check for possible trouble codes, free.
To check for spark, you can pull a plug wire, stick known good spark plug or spark tester in the boot, ground metal part to metal part of engine. Engine cranking, watch for spark.
Feb 16, 2010 at 6:34 AM
