1996 Chevy Corsica Relay switches
144,000 MILES • 6 CYL • FWD • AUTOMATIC
SHEAFFERD
Hi, My car has a mind of its own. For some reason the radio light goes dims and then comes back on to full bright . Like when you turn on your nights lights. Only my lights come on automaticly when you start the car so there is no need to touch the switch. When the light on the raido goes dim there is a noise like a relay switch making contact. This also makes my head likes go dim for a second then back to normal if you can call it that. Is there a relay that I can replace?? Doesn't cause a problem, just botherson. Thank you.
Mar 9, 2010 at 5:10 AM
LEGITIMATE007
  • 5,121 POSTS
does it seem like the sound is coming from behind the center console?
Mar 30, 2010 at 1:30 AM
