1996 Chevy Corsica heater hose routing
1996 CHEVROLET CORSICA
PICKUP
Heater problem
1996 Chevy Corsica 6 cyl Front Wheel Drive Automatic
I want to flush the heater core but the only way I can see the hoses are from under the car. Where are the hoses located at the pump? They are rubber hose from the core but are then connected to metal lines. Any help you can give me would be greatly appreciated as doing this from under the hood would sure beat getting a face full of coolant. Thank you
Dec 3, 2008 at 3:52 AM
DOCFIXIT
  • 18,828 POSTS
Is your problem no heat? If so is thermostst good engine temp. normal? May have a blend door problem. I think there is a rubber hose up by thermostat that could be used but a hose will still have to come off one core line.
Dec 3, 2008 at 11:47 PM
