i will condense it for you as step by step will take a long time and you should use a auto repair manual for that.
to change the head gasket the best thing to do is remove the valve covers, intake manifold and then remove the heads, just disconnect and mark all wires before you remove it.
Jan 14, 2008 at 11:37 AM
