1996 Chevy Corsica fuel
11,000 MILES • 6 CYL • FWD • AUTOMATIC
CARLOSERICE
Poor gas mileage and strong smell of gas
Sep 24, 2010 at 8:39 AM
JDL
  • 16,098 POSTS
Follow the fuel lines, check for leaks, under the vehicle,in the engine compartment. Check around the fuel injectors. Pull the vac line from the pressure regulator, see if any gas in the line. Any applicable trouble codes? If you check codes yourself, at the least, you need an obd2 code reader.
Sep 24, 2010 at 9:16 AM
