Follow the fuel lines, check for leaks, under the vehicle, in the engine compartment. Check around the fuel injectors. Pull the vac line from the pressure regulator, see if any gas in the line. Any applicable trouble codes? If you check codes yourself, at the least, you need an obd2 code reader.
SPONSORED LINKS
Friday, September 24th, 2010 AT 4:16 PM
