1996 Chevy Corsica Bad ignition coill?
1996 CHEVROLET CORSICA
180,000 MILES • 6 CYL • FWD • AUTOMATIC
ANDERPAW
About a month ago the car was tuned up. The plugs were replaced and a couple of wires as well. The mechanic said one of the coils was going bad and he didn't want to replace it because it may cause one of the other coils to go bad. Since that time the car starts fine, but if I shut the engine off for any amount of time and attempt to restart it, it will not turn over. Depending on how I pump the accelerator, the engine will start. When I do have the car running and I rev the engine, the rpms drop and the engine acts like it is going to stall. Could a bad ignition coil be the culprit?
Apr 4, 2010 at 9:34 AM
HMAC300
  • 48,601 POSTS
I don't quite understand this. You say it won't turn over but then it will start and run poorly. Yes the coil cold cause this but the not turning over part is eitehr a battery or starter problem not the coil. if you go to an auto parts store they can test the battery as a bad or poor shape battery will cause this as well.........
Apr 10, 2010 at 7:05 AM
