1995 Chevy Corsica not cranking
1995 CHEVROLET CORSICA
120,000 MILES • 4 CYL • FWD • AUTOMATIC
GREENHORN4311
car is getting fire and fuel but wont crank (not even on starting fluid)... not sure about fuel pressure, theres no connector to check but is getting fuel to the feed line... replaced crankshaft position sensor, but no dice... plugs are wet with gas when it turns over... could it have jumped timing, if so whats a good way to check? car is a 95 corsica 2.2 4 cyl
Mar 3, 2010 at 10:47 AM
LEGITIMATE007
  • 5,121 POSTS
could have jumped timing, a good way to check is do a compression check. i'll send some info
Mar 18, 2010 at 1:39 PM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
you said the plugs were wet, that means there is not spark righ? so I would check the spark again
Mar 18, 2010 at 1:42 PM
LEGITIMATE007
  • 5,121 POSTS
