1996 Chevy Corsica abs
130,000 MILES • 6 CYL • FWD • AUTOMATIC
TWISTER699
I have bought this chevy corsica and it needed an intake gasket, replaced that and it fixed that problem but my abs light is on. i read in the owners manual that if it stays on it means the abs is not working properly but the brakes do. When i hit the brakes the back brakes grip and lock up first! Hoping you can please help me with my problem. Thank you......
Aug 13, 2008 at 12:05 PM
IMPALASS
  • 3,112 POSTS
Check the brake fluid level first....fill if necessary and then see if it goes out when driven.....if not, then see below.
DESCRIPTION
This lamp will be illuminated when the ignition switch is placed in the ON position. The lamp may be illuminated for as long as 30 seconds as a bulb and system check. If lamp remains illuminated or comes on while operating the vehicle, a problem in the anti-lock brake system is indicated.
OPERATION
When lamp is illuminated, place ignition switch in OFF position, then restart engine. If lamp still remains illuminated, the antilock brake system should be serviced. The brake system will remain functional, but without the anti-lock function. After servicing the anti-lock brake system the lamp will automatically reset.
NOTE : On some models it may be necessary to operate vehicle at a speed over 18 mph to reset lamp.
DESCRIPTION
This warning lamp can be activated by a low brake fluid condition, a closed parking brake switch, a bulb test switch section of the ignition switch is closed or under the control of the EBCM/EBTCM when certain ABS diagnostic trouble codes are set.
Also, there are some technical service bulletins out on ABS lights. Have you taken it to Auto Zone and had the codes pulled for free? Check that……..you can email me once you have pulled to codes to let me know what they were and I can send you those tech bulletins.
Oct 2, 2008 at 3:15 PM
