1996 Chevy Corsica 1)my car shakes at 40mph/2) turn signals
1996 CHEVROLET CORSICA
SYLVIACAGGIANO
Shakes or Wobbles problem
1996 Chevy Corsica 6 cyl Front Wheel Drive Automatic
1) why would it shake and wobble once it reaches 40 mph?
2) i checked my fuse and it is working and the flasher works. at first it would need to be turned off manually after negotiating the turn (right or left) then it just stopped flashing at all. why????????????
Nov 29, 2008 at 9:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Shaking is most likely cause by wear and tear on the vehciles suspension. A simple alignment at a local shop will usually cure this. Could be caused by worn wheel bearings or ball joints as well, which alignment shop can tell you if this is the case.
For the turn signals, it sounds like your multi-function switch (switch that turns signals on) could be faulty. Check for power going to the switch. If power is there, switch needs replacing.
Nov 29, 2008 at 4:02 PM
