1994 Chevy Corsica Shakes while driving and putting a load
182,200 MILES • 6 CYL • 2WD • AUTOMATIC
PHILLIPSHCWARTZ
Very new fuel filter and air filter, checked plugs on the front three and they look pretty clean and gapped. When we go up slope and when we are at highway speeds higher than about 45mph or so it shudders. The shifting seems ok as it passes through speeds and down shift when stomping on the gas works fine too and we get good acceleration, however at normal speeds around 65 or 75 when we slowly accelerate, the shuddering happens.
Aug 31, 2009 at 8:37 AM
BIGJIM79
  • 239 POSTS
Its the overdrive solenoid. It is barely engaging causing it to slip. it will soon go completely out or worse go into OD and not release and stall at every stop and won't take off.
Nov 30, 2009 at 5:18 PM
