1996 Chevy Corsica 1996 Chevy Corsica Check Engine Camshaft
285,000 MILES • 4 CYL • FWD • AUTOMATIC
SHRYUKE
My corsica is running fine and is putting out a Check Engine light with the code corresponding with Camshaft Positioning Sensor. I have replaced the computer and had the firmware flashed and have replaced the sensor itself but after I reset the check engine light it comes back on within seconds with the same fail code.
Jun 25, 2010 at 5:35 PM
HMAC300
  • 48,601 POSTS
check your pins as the computer was replaced and it may have bent a pin. Or the connection on the cam sensor is not making a good connection. Also check the grounds on the car for being dirty. There is a possibility if it was a cheap/poorly manufactured sensor that the ohms are to high and causing this as well.
Jul 3, 2010 at 6:13 AM
