1995 Chevy Corsica Windsheild Wiper
138,000 MILES • 4 CYL • FWD • AUTOMATIC
DAM FAST
The passenger side windshield wiper will not go all the way to the bottom of the windshield. It passes into the path of the driver side wiper and hangs onto it, tearing off that blade.
Is there an adjustment that can be done to the wiper to put it back to the right track?
Feb 15, 2010 at 6:12 AM
HMAC300
  • 48,601 POSTS
windshield wipers have a few things to them. a motor, a transmission and the wiper where the blade connects to. I forget what they call that. anyhow you will need to pull the vent part off of your car or just look with a lot of light and you may see a clip or the transmissino broken. that is what you will need. YOu'll have to see if you need th eclip to put the transmission back together or the transmission itself.you will probably have to pull both wipers off to get the vent off to fix this. the auto parts my have the clip and maybe have the transmission available. But that used to be a dealer part so your other option would be a junk yard if not available locally or online.
Feb 17, 2010 at 12:30 PM
