1995 Chevy Corsica Wet Weather Starting
SPATTJSGT
Electrical problem
1995 Chevy Corsica 4 cyl Front Wheel Drive Automatic
Good day,
I own a 95 Chev Corsica which seems to have one small problem. When there is a hard rain storm, the vehicle will crank over but not fire. Someone suggested that it was either my Ignition Control module or the coil pack. Any thoughts?
Mar 24, 2009 at 1:06 AM
DOCFIXIT
  • 18,828 POSTS
Maybe crankshaft position sensor located lower right side engine near oil filter. Check weather head wire connector moisture can cause sensor to fail.
Mar 25, 2009 at 2:24 AM
