1995 Chevy Corsica Trying to figure out why my brakes are d
1995 CHEVROLET CORSICA
108,000 MILES • 4 CYL • 2WD • AUTOMATIC
MILLIEE
I've had my car to a mechanic and my brakes still do this. They replaced the abs sensor. This is very hard to explain but I'm going to explain it the best way I can. My car doesn't do this all the time, but it mainly happens when I'm pulling out of a parking lot, drive way, etc. It only happens when I am going at a real low speed, and maybe when I have the steering wheel turned a certain way, I'll put on the brakes & they don't work and it makes this low tone noise in the car that I really can't describe, What could be causing the brakes not to work?
Mar 1, 2010 at 1:58 AM
BIGJIM79
  • 239 POSTS
this is from the proportioning valve opening. It is caused by a bad wheel sensor on your axle causing an open circuit
Mar 29, 2010 at 4:31 PM
LEGITIMATE007
  • 5,121 POSTS
I agree with bigjim79. the wheel sensors need to be checked, probably has a chip in one of the "tone rings".
Mar 30, 2010 at 1:34 AM
