1995 Chevy Corsica Surging engine and black smoke.
186,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGGMEANY2000
My car has recently been getting terrible gas mileage, smoking black smoke when accellerating, and surging or jerking when cruising. I recently replaced my MAP sensor. It still has same symptoms. My next guess is a fuel pressure regulater. Any help would be great.
Oct 13, 2008 at 1:08 AM
  • 75,988 POSTS
Your guess might be right-if you check the fuel pressure -pull the vacuum hose at the regulator do you see fuel-if so you've located the problem
Oct 15, 2008 at 11:25 PM
