1995 Chevy Corsica starter
MARK C.
Electrical problem
1995 Chevy Corsica 6 cyl Front Wheel Drive Automatic
this car died while in motion and would not restart. it seemed the seliniod was bad so i replaced it,no luck so i put another starter on it but it does the same thing, will not ingauge or turn with a good battery. what am i missing?
Jan 17, 2009 at 7:43 AM
KEVIN12881
  • 336 POSTS
The starte would not cause the vehicle to die.. and is the starte silinoid not on the starter? You say the engine cranks, but will not start.. If your engine turns but does not start check the following, Fuel tank empty, battery discharged, battery terminals loose or coroded, fuel not reaching injectors, faulty distributer, low cylinder compression, water in fuel, dirty or clogged injectors, wet or damaged ignition components, worn faulty or incorrect gapped spark plugs, timing chain fracture or wear, fuel filter..... can you check for spark and fuel?
Jan 17, 2009 at 7:57 AM
MARK C.
no the bendex will not even engage to the fly wheel therefore the engine will not turn over
Jan 17, 2009 at 9:12 AM
KEVIN12881
  • 336 POSTS
you may have a faulty wire. donate a few bucks and get a pro to help.. i m out of ideas right now.
Jan 17, 2009 at 9:16 AM
MARK C.
well thanks for the help.
Jan 17, 2009 at 9:22 AM
