1995 Chevy Corsica Spark Plug wires
HDYMN53
Engine Performance problem
1995 Chevy Corsica 4 cyl Front Wheel Drive Automatic 112K miles
I know how to change wires from the front, but the wires go behind the engine, how do I get to them and change the wires.
Oct 7, 2009 at 6:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
remove the coils off the top and then remove all the other connectors off and vacuum lines. Should be able to see the wires and plugs now, may have to lean over engine some. Will just have to work with extensions and swivels to reach the plugs unless you just want to remove more components.
Oct 27, 2009 at 10:41 AM
