My 95 corsica shaking & wanting to stall especially when stopping or decelleration. Got car home & it would not start w/out having gas to floor, it starts but runs really rough as if only on 2 cylinders. I replaced everything I could think of to fix it,(to no-avail). First I got new plugs,wires & ing. coil packs and replaced all. Then I removed fuel tank and replaced fuel pump & filter(Needed it also) Then I thought the Cat. Conv. could be plugged so I bypassed it & (still rough). I have tried everything I can think of. I have already purchased too much and still not fixed. I must get it figured out! I have done some research and will try to disconnect TCC and see if that works. Is there another censor or something else mal-functioning to cause this?(If so pls explain location) Please take time to read this I really need the help thx.
Feb 10, 2010 at 11:00 AM
