1995 Chevy Corsica knocking sound
833,000 MILES • 6 CYL • FWD • AUTOMATIC
ADELINE2U
knocking sound in right rear on right turn
Feb 20, 2009 at 3:13 AM
IMPALASS
  • 3,112 POSTS
Hello - When was the last time you replaced the shocks? They could be allowing the body to bump on the springs. The upper insulator on the springs could be worn allowing body to spring vibrations. Your shocks may be loose..........with the weight on the wheels apply the proper torque to the nuts. I would also check the bushings in the control arms etc. I have attached a pic for you...........
https://images.2carpros.com/forum/automotive_pictures/248015_Corseca_rear_1.jpg
Mar 1, 2009 at 2:51 AM
