1995 Chevy Corsica Knocking
45,700 MILES • 6 CYL • 2WD • AUTOMATIC
95V6CORSICA
Ok, my car makes a knocking noise when at operating temperature that you can only hear from inside the car. You can't hear it at all from outside the car. And the noise is only at idle. Oil level is full and there is no oil pressure light on. I am using synthetic 5w-30 in my car, could this be why? should I switch to conventional and would that help?
thanks
Nov 8, 2009 at 3:36 PM
BIGJIM79
  • 239 POSTS
This sounds like a case of weak oil pressure. The motor mount could be broke letting the motor rest on the exhaust.
Nov 29, 2009 at 6:59 AM
