1995 Chevy Corsica DEFROST UNIT & WATER CIRCULATION
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEJUAN
MY CAR PUT OUT HOT AIR THRU ALL VENTS EXCEPT TOO THE WINDSHEILD.
I FLUSH MY RADIATOR & REFILLED; REPLACED WATER PUMP; REPLACE THERMOSTA.
BUT NO PRESSURE ON TOP WATER HOSE WHEN SQUISED.
YOUR HELP IS GREATLY APPRECIATED!!!!
Oct 24, 2009 at 11:17 AM
  • 110,248 POSTS
The air to the windshield could be cause by a vacuum leak. As far as the pressure in the cooling system, make sure the coolant isn't mixing with the oil in the engine.
Let me know what you find.
Oct 29, 2009 at 12:36 AM
