1995 Chevy Corsica crank sensor
ROMONI00
Engine Performance problem
1995 Chevy Corsica 6 cyl Front Wheel Drive Automatic
where is this thing located and how can change it
Nov 8, 2009 at 5:33 AM
JDL
  • 16,098 POSTS
welcome to the forum, check, backside of engine block, down low. If that is the original sensor with the thin flange that sits on the block, that can get brittle. Probably a bolt that holds the sensor, then you pry up on the sensor.
Nov 8, 2009 at 5:49 AM
