1995 Chevy Corsica computer fuse blowing
90,000 MILES • 4 CYL • FWD • AUTOMATIC
MOOSELANDGEORGE
Computer fuse keeps blowing, thus engine will not stay running. Checked connections at computer for corrosion, changed computer still blows fuse.....HELP
Jul 18, 2009 at 11:52 PM
JDL
  • 16,098 POSTS
Hello, just a thought, unplug B+ from the ignition module, the ignition module is under the coil pack. The pink wire is voltage. Then see if the fuse still blows?
Jul 19, 2009 at 2:13 AM
JDL
  • 16,098 POSTS
Hi, glad you got it going. You need to be aware, plugs--plug wires--ignition coils can all have an effect on the ignition module.
Aug 11, 2009 at 2:52 AM
