1995 Chevy Corsica Chevy Corsica 1995 gearshifting speed pr
D30DK
Engine Performance problem
1995 Chevy Corsica Automatic
I own a Chevy Corsica 1995 with 3 shifting.
The second shift is moving at 30mph.
Third shift is moving at 62mph.
When the speed is dropping to 50mph the gear is down to second shift.
I must go to these speeds so the gear will shift....It's really not normal.
The computer car was checked and there aren't any errors...
What is the problem?
Thank you!
Feb 12, 2010 at 11:29 PM
HMAC300
  • 48,601 POSTS
check to see if your cable from the throttle to the trans is stuck or broken. sounds like you have to much throttl pressure causin g this...or let a trans guy look at it.
Feb 17, 2010 at 12:36 PM
