1995 Chevy Corsica car starting
119,000 MILES • 4 CYL • 2WD • AUTOMATIC
BIOMECHANOID12
Recently my car just wouldn't start. It turns over, the fuel pump engages, but it won't get whatever else it needs to start. I checked the ignition coil, the battery, the fuel lines, replaced the spark plugs, and check the plug wires. I was wondering if it was the distributor cap, or the module underneath. Any ideas?
Mar 21, 2008 at 1:32 AM
JDL
  • 16,098 POSTS
If you have the 2.2 litre engine, there is no distributor. Did you check for spark at the plugs? You can take a plug wire loose, stick a known good plug in the boot, lay metal part of plug against engine ground. Have helper crank the engine, while you check for spark at the tip of the plug.
Can you check for troublecodes?
Mar 24, 2008 at 8:06 AM
