firing order?
145,000 MILES • 4 CYL • FWD • AUTOMATIC
CHILIDOG09
what is the firing order?
Oct 3, 2009 at 12:56 PM
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_95_corsica_firing_order_1.jpg
2.2 vin G Firing order 1-3-4-2
Oct 4, 2009 at 2:01 AM
SMILLER3184
looking for a firing order diagram on this vehicle engine is 3100 SF1 V6 need schematics, pictures, or whatever
Jan 18, 2021 at 3:53 AM (Merged)
  • 75,988 POSTS
Here is the engine spark plug firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed....................
Cheers
DIABETIC_SKATER
i have recently replaced all my wires and plugs but think i crossed a wire and am trying to figure out the order from each coil to plug
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_corsica_firing_order_1.jpg
hello, the above info is for a 3.1
JACK BACK
Need diagram of firing order for 95 Corsica 2.2 L
Jan 18, 2021 at 3:54 AM (Merged)
  • 110,248 POSTS
Take a look through the attached pics and let me know if they help. The last picture is for wire routing. Here is the actual firing order:
1995 Chevrolet Corsica L4-2.2L VIN 4
Ignition Firing Order
Vehicle Powertrain Management Ignition System Firing Order Specifications Mechanical (including Torque) Ignition Firing Order
IGNITION FIRING ORDER
Firing Order .................... 1-3-4-2
Let me know if this helps.
CHRIS&GARY
Engine Performance problem
1990 Chevy Corsica 4 cyl
need to know the firing order for a 1990 chevy corsica four cylinder
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_corsica_2.jpg
the picture may be different depending on the VIN, but the firing order is 1342
CHRIS&GARY
thank you very much you have been a great help!
PCHPOOCHIE
hello how are yall doin i really have to question the first is what's the firing order the car above and what's the firing order on a 1996 chevy beretta the reason i asked for dat one because i tried to wire the corsica up like that one thinking it might have the same firing order now i got it off track too thanks for yur help
BMRFIXIT
  • 19,053 POSTS
this is 3.1 L 2nd pic 3.3L 3rd pic 3.8L
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic_26.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_5.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_6.jpg
  • 75,988 POSTS
3.1L
https://images.2carpros.com/forum/automotive_pictures/12900_fo_3_1.jpg
96 Beretta
https://images.2carpros.com/forum/automotive_pictures/12900_96_beretta_1.jpg
HAYLEYC
I have a 1995 Chev Corsixca. What is the firing order?
DANCARLSON
  • 50 POSTS
If it is a 6 cylinder the cylinder numbers are
at the front 2-4-6
at the back 1-3-5
The firing order is 1-2-3-4-5-6
If it is a 4 cylinder the cylinder numbers are (drivebelt end to transaxle end)
1-2-3-4
The firing order is
1-3-4-2
Dan
