1994 Chevy Corsica wheel bearings......
180,000 MILES • 4 CYL • FWD • AUTOMATIC
SXYTINKERBELL0886
can a wheel bearing make the abs light come on or no? cause i have this guy telling me that is whats wrong... and i had another guy tell me that he is wrong.... do im hoping that you can help me with this....
Aug 16, 2008 at 7:23 PM
2CARPRO JACK
  • 11,533 POSTS
Sure can, The sensor is in the hub assembly and if the bearing gets bad it can create "noise" that will interfere with the sensor or if the bearing is real bad I have seen them actually break the end of the sensor... hope that helps Tinkerbell
Aug 17, 2008 at 2:04 AM
