1994 Chevy Corsica water inside vechuile
SANFUS56
Interior problem
1994 Chevy Corsica 6 cyl Front Wheel Drive Automatic
why is there water inside car on the drivers side , only under the feet and no where else
Dec 27, 2008 at 5:50 PM
BMRFIXIT
  • 19,053 POSTS
Is it water or coolant
if coolant (it is green in color and has a sweet smell) check and suspect heater core
if clear in color water
and it happens after running AC or defrost
AC drain is clogged and need to be clean
its under the hood on the firewall passenger side
best to reach it is from under the car
u can use compressed air and or a shop vacuum
let me know
Dec 27, 2008 at 9:31 PM
SANFUS56
It never smells until it sours. So I guess it clear water I noticed it more when driving with the heat on. I don't see a trail of where it is coming from it always just puddles the next morning
Dec 28, 2008 at 1:26 AM
BMRFIXIT
  • 19,053 POSTS
Check coolant
when heater on defrost does the windshield fog up ?
I do not think its the heater core !
I believe you need to clean the HVAC drain
if it happen after a rain storm check the windshield seal
check air inlet under the hood
Dec 28, 2008 at 10:37 AM
