1994 Chevy Corsica turnsingle
TRHUDSON
Electrical problem
1994 Chevy Corsica 4 cyl Two Wheel Drive Automatic
1994 Chevrolet Corsica; Why do the turn singles flash at abnormal rate and a couple times have stopped? and How do I repair?
Sep 7, 2010 at 3:32 AM
SATURNTECH9
  • 30,869 POSTS
So does your turn signal flash faster then it usually does?If so the first thing i would check is that all your turn signal bulb's work.If the all do then you could just have a bad turn signal flasher relay.
Sep 7, 2010 at 8:13 AM
