1994 Chevy Corsica rack and pinion or power steering proble
233,000 MILES • 6 CYL • 2WD • AUTOMATIC
OLDSLEDDER
I notice when making a lane change that the steering is a little hard to turn. It also makes a noise when turning the steering wheel in either direction. But it turns very easily when doing this. Are these symptoms of a power steering pump going bad or possibly a worn out rack and pinion?
Regards,
Mike
Feb 5, 2009 at 5:04 AM
DOCFIXIT
  • 18,828 POSTS
Sounds like pump what happens when parked and turn? is fluid full? They make an additive that may do some good.
Feb 5, 2009 at 8:11 AM
OLDSLEDDER
I have tried the additive, didn't help. Fluid is full. When parked, it turns easily without any additional effort, however it does make a noise no matter which direction I turn.
Feb 5, 2009 at 9:52 AM
DOCFIXIT
  • 18,828 POSTS
Then it's a pump growl but if it turns good and you can still hear the radio I'd run with it. Save your pennies for pump replacement in future. I drove a Ford F150 90k with a growler before it died.
Feb 6, 2009 at 7:32 AM
