1994 Chevy Corsica oil filter
1994 CHEVROLET CORSICA
DBEAR1952
Engine Cooling problem
1994 Chevy Corsica 4 cyl Front Wheel Drive Automatic
I have looked every where and cant find the oil filter. Where is it located.
Feb 14, 2009 at 10:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
On most of these engines, the oil filter is located at the back of the engine. It is impossible to reach from above, and almost as inaccessible from below. On these engines, it may be easiest to remove the right front wheel and tire assembly, then reach through the fender opening to access the oil filter.
Thanks for using 2CarPros.com!
Feb 15, 2009 at 12:41 AM
