1994 Chevy Corsica low coolant
135,000 MILES • 6 CYL • FWD • AUTOMATIC
STAYTUNEDN
The low coolant lamp came on, I added coolant to the car to bring the levels to there proper level. The low coolant light did not go out, what else could be the problem or do i get the light out?
Mar 4, 2009 at 12:37 PM
BLACKOP555
  • 10,386 POSTS
you could have a bad coolant level sensor. is the resevoir and the radiator both filled to full????
take out the sensor and see if its corroded and check it for proper function.
Mar 4, 2009 at 1:39 PM
