1994 Chevy Corsica High beam switch
46,000 MILES • 4 CYL • FWD • AUTOMATIC
APD3267
The indicator switch works for left and right but will not turn on the high beams when pulled. Do I have to replace the switch? If so, how?
Jul 8, 2009 at 3:51 PM
BIGJIM79
  • 239 POSTS
The switch is easy to replace. It may need adjusting though. Remove the cover under the steering column and put aside. The switch will be on the left side of the column and will have a rod going to it. If you need to you can move the dimmer and folow the rod down to the switch. It will be held on bi a bolt and a nut. First loosen both and move toward the steering wheel. Tighten down and try again. If still not working will need to be replaced. Just remove the bolt and nut and unplug connector. Replacement is opposite of removal with adjustmenta s fore mentioned.
Nov 28, 2009 at 5:25 PM
