1994 Chevy Corsica heater core
WENDY1975
  • 1994 CHEVROLET CORSICA
  • 6 CYL
  • FWD
  • 10,000 MILES
1994 chevy corsica that leaks water from the firewall near the heater core hoses there a rubber elbow but no hose attachs to it.
Friday, August 8th, 2008 AT 5:53 PM
CAR TOM
  • 45 POSTS
I have replaced a heater core in my corsica about 9 months ago. The heater core has a plastic liner/tub hannging underneath it which collects moisture-leaks and does have a small elbow which passes thru the firewall to dump the water onto the ground. If you are leaking thru that elbow quite a lot chances are your core is bad. The oem core was a dim witted design it has two plastic tubes press fit onto the aluminum core in my case the core was fine but the plastic tube cracked in half causing a leak.
Wednesday, August 27th, 2008 AT 12:28 PM
