1994 Chevy Corsica bad shaking
164,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHAIRD
hello my moms corsica when about 35 mph shakes real bad the car shakes & the steering wheel wil move & it only gets worse the faster you go but around 60plus it will stop for abit then when you accelerate it will shake more
Mar 22, 2010 at 5:05 AM
JDL
  • 16,098 POSTS
Hi, I wouldn't drive it like that. If nothing else, take it to an alignment shop. You could safely raise and support one tire at a time. Push and pull, try to move up and down on the tire, roll, where applicable. See if you can see--feel--or hear anything. Run your hand around the thread, see if you feel any bad places, knots, anything. Are the tires in good shape? You might rotate the front tires to the rear, don't know if it will help? Maybe the suspension has a problem?
Mar 22, 2010 at 8:11 AM
HOWARDHUNTS
Your tires may need to be balanced and checked for wear
Mar 23, 2010 at 4:54 AM
