1994 Chevy Corsica '94 Chevy Corsica
TXCHICK86
Transmission problem
1994 Chevy Corsica Automatic 133000 miles
The transmission is acting funny in my corsica. When I press on the gas, the car slows down a little and then afer about 10 seconds or so, it seems like it pops into gear because I'm not excelerating quickly. It some times feels that you are on a tetter-totter when going down the highway and i dont know why. what is the best solution to this? replacing the transmission or is it an engine problem?
Oct 1, 2008 at 8:50 AM
  • 110,248 POSTS
Hi:
Based on your description, it sounds more like the engine is missing or almost shuting down. Does it do this at any speed? Also, when you first pull out from a stop, does the vehicle accellerate in a normal manner?
Let me know so I can try to direct you.
Oct 2, 2008 at 6:24 AM
TXCHICK86
It only usually does the "swaying" or teeter-totting when it gets over 55. It seems to have a problem first getting started and up over 15 and then again has trouble getting over 55-60. As long as I keep my foot on the accelerator while its swaying, then it'll stop after about 15 seconds but then go it again about a minute or two later.
thanks for your help...
kadie
Oct 2, 2008 at 8:30 AM
