Hi, and thanks in advance for the help.
I have a '93 Corsica, 3.1L V6. with About 235,000 Kilomitors. (Canada) But the problem is with the rear defrost. When ever I turn it on, the lights dim, the turn signals start blinking VERY slow, and the heater fan slows down. - Sounds like not enough power from the Alt, or Battery. But I already replaced both with better than average parts. That did lessen the problem a little bit, but I would really like to fix it. I do have one defrost line on the back window that's dead. I know where the brake is in the line. But chose not to fix it until this problem is fixed. One other note this problem has always been there since I bought the car used. I have installed a few small stereo upgrades since then, but the problem is no better or worse. So I'm wondering if it's just a short in the rear defrost.
Feb 10, 2007 at 4:39 AM
