1993 Chevy Corsica Wheel Cylinder
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
SNOWICKI
How do you remove the wheel cylinder? The hub is in the way of it coming out all the way. I have tried wiggling it out tried prying it out and even tried using a hammer and a long screwdriver to just knock it out, however it is still getting caught up by the hub. Is it really necessary to take the hub off or is there some trick to it?
May 3, 2010 at 1:12 PM
HMAC300
  • 48,601 POSTS
nope the hub has to come off, there should only be 3 or 4 bolts holding it on.....
May 10, 2010 at 10:59 AM
