1993 Chevy Corsica timing
12,000 MILES • 4 CYL • FWD • AUTOMATIC
JASON PREHODA
if i got the firing order wrong would it screw up the timing???
May 21, 2010 at 7:49 AM
INTERNETMECHANIC
  • 700 POSTS
It depends? On older systems, as long as you get the proper plug wires on the proper coil, It shouldn't matter about coil tower. Cylinders one and four go to the same coil. Cylinders three and two go to same coil. This info for 2.2L engine.
https://images.2carpros.com/forum/automotive_pictures/512072_chevy_corsica_firing_order_1.jpg
May 21, 2010 at 8:02 AM
JASON PREHODA
is the 2314 the order on the coil???for a 2.2
May 21, 2010 at 8:10 AM
INTERNETMECHANIC
  • 700 POSTS
Yes, according to the database.
May 21, 2010 at 8:42 AM
