My tailpipe smokes when I drive. Im not sure what would cause this. How do I fix it.
Thursday, April 30th, 2009 AT 2:31 PM
LEGITIMATE007
MECHANIC
There are three colors of smoke, white, blue, and black, what color is the smoke and is there a check engine light on?
SPONSORED LINKS
Thursday, April 30th, 2009 AT 2:44 PM
ATKAPARKING
MEMBER
Check your fluids too, specifically oil and coolant (while the engine is cold). If one of these is low, it will give you clues on what to look at next.
Friday, May 1st, 2009 AT 4:16 PM
LEGITIMATE007
MECHANIC
Atkaparking is absolutely correct, that way should indicate which fluid is being consumed if any, Top off your fluids, and pay close attention, checking them a couple of times a day, even brake fluid or transmission fluid can end up in your combustion chamber causing smoke and or a foul smell
Friday, May 1st, 2009 AT 5:15 PM
LEGITIMATE007
MECHANIC
Your vehicle could be running rich, which will cause smoke too
Friday, May 1st, 2009 AT 5:16 PM
DREAMDIETY
MEMBER
Its black smoke. Whats rich im kinda illiterate to cars
SPONSORED LINKS
Saturday, May 2nd, 2009 AT 10:48 AM
LEGITIMATE007
MECHANIC
Rich basically means too much gas, and black smoke does mean fuel. So I will send you a link that will show you how to check fuel pressure and what to do about it
