1993 Chevy Corsica Ignition or brakes
1993 CHEVROLET CORSICA
263,198 MILES • 6 CYL • FWD • AUTOMATIC
MR.LEMON
I got a 93 corsica 3.1L multiport V6 and it has 260kmi on it, and I got it cheap (really cheap)
anyway it doesn't start, pulled the air box and found oil+gas sitting in a small puddle, anyway when I go to start it, it occassionally backfires in the intake only never an exhaust backfire always in the same cylinder the others don't fire, checked spark and found that only one spark plug fires but it keeps moving to which spark plug fires (btw it has a very very strong spark, while two have weak sparks, one is weak and intermittant and two don't fire ever)
When I first purchased the vehicle I was told it needed a timing chain which turned out to be false
but now I wonder ive been told to replace the modules (which I am willing to do) but if is the master computer (the ignition trigger signal) then the car is porbably just junk (too expensive for me)
otherwise could the brake booster diaphragm be blown and how to test for that without a running engine.
Mar 1, 2010 at 5:37 AM
LEGITIMATE007
  • 5,121 POSTS
check/change the pcv valve. you have blowback in the air box, causing the back fire. also may cause the misfire,thus causing the no start condition. also the check the brake booster, remove the vacuum hose while the engine is running, if it leaks or the idle doesnt change, then you have a bad diaphram.
Mar 1, 2010 at 6:42 AM
