1995 Chevy Corsica brakes sticking
HODGE123
Brakes problem
1995 Chevy Corsica 4 cyl Front Wheel Drive Automatic
my right front caliper sticks. i replaced it with a new one.
Nov 16, 2009 at 12:36 AM
BIGJIM79
  • 239 POSTS
I know you probably bled them so I will skip that. LOL I know that some of the valves stick on the abs side. It should have bleed valves at the valves for each wheel. Try bleeding them. If that doesn't work it may be the wheel sensor not working on that wheel. This should cause the ABS light to come on but not always. This would cause the wheel to grab and lock up.
Nov 28, 2009 at 4:51 PM
