1993 Chevy Corsica Has no spark
CINDYK
Electrical problem
1993 Chevy Corsica 6 cyl Front Wheel Drive Automatic
If the crank sensor is bad would it cause it not to have spark
Nov 26, 2009 at 11:31 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 26, 2009 at 11:37 AM
